Create a Shortest Path Bridging MAC (SPBM) Backbone VLAN (B-VLAN). Each SPBM network
instance is associated with at least one backbone VLAN (B-VLAN) in the core SPBM
network. This VLAN is used for both control plane traffic and dataplane traffic.
As a best practice, configure two B-VLANs in an SPBM dual-homing environment.
In the navigation pane, expand
Select VLANs.
In the Basic tab, Select
Insert.
In the Id box, enter an
unused VLAN ID, or use the ID provided.
In the Name box, type
the VLAN name, or use the name provided.
In the Color Identifier
box, select the down arrow and choose a color from the list, or use the color
provided.
In the Type box, select
spbm-bvlan.
Select Insert.
Collapse the VLANs tab.
The VLAN is added to the Basic
tab.
